TZR 125 YPVS
Hello i have a TZR 125 1990 2RK, im looking to set the YPVS.
Could anyone tell me what models of the DT will fit my bike and any others .
I have which i believe needs the control box ( not sure if its the 3 wire or 5)
So does anyone know how to gain the control box or could help me out ?
Thanks Guys
Hi TZR-man. You should post an intro in the new member section. You might get a better response if you do. :)
Quickly could you tell me if a 3 wire DT125 2000 will fit my bike ?
It is good form on here to post the intro. That doesent count when you post a question as an intro.
You are asking a question that will take time to answer properly but have put nothing in.
Many forums make you wait or approve early posts. That doesent happen on here but an intro is expected by the masses. Nothing extensive. Just a bit about you and your bike.
Would you walk up to a group in a pub and bang straight in with a question.....
  • 3 weeks later...
Hello will the 3 wire from a 1991 fit the 1990 ?
You have asked the same question time and again with the same responses.
Introduce yourself and add to the group or, as it appears, the group will not respond.
