XS250 Help
I bought my XS250 not long ago but i'm finding it hard to get hold of parts a friend suggested i look at other models and see if those parts can be fitted to the xs250 but i can't figure out what will fit can anyone give me some help?
try a company called pattern parts which you can compare part numbers only do limited stuff but you get some ideas failing that get a haynes manual and look through it
I got a haynes manual that covers 250,360 & 400 does that mean for example the 400 wheels would fit the 250?
just because a manual refers to a brace of machines doesnt necessarily indicate parts compatibility
the engines are all very similar enough to be covered by the one manual but they
are all very different machines
it is a case of trial and error when swapping parts over but i would have expected the wheels and major cycle parts to be easily moved over as most Yams from the period followed a similar sizing making swing arms and forks a relatively easy thing to exchange
  • 3 years later...
click here for compatibility list
try this site has helped me out a lot with swapping parts
why are you answering a question from 2005?
can you please see the sticky regarding sig size as its too big mate HERE
