May 29, 200520 yr I bought my XS250 not long ago but i'm finding it hard to get hold of parts a friend suggested i look at other models and see if those parts can be fitted to the xs250 but i can't figure out what will fit can anyone give me some help?
May 30, 200520 yr try a company called pattern parts which you can compare part numbers only do limited stuff but you get some ideas failing that get a haynes manual and look through it
June 3, 200520 yr Author I got a haynes manual that covers 250,360 & 400 does that mean for example the 400 wheels would fit the 250?
June 4, 200520 yr just because a manual refers to a brace of machines doesnt necessarily indicate parts compatibility the engines are all very similar enough to be covered by the one manual but they are all very different machines it is a case of trial and error when swapping parts over but i would have expected the wheels and major cycle parts to be easily moved over as most Yams from the period followed a similar sizing making swing arms and forks a relatively easy thing to exchange
April 5, 200916 yr click here for compatibility list try this site has helped me out a lot with swapping parts
April 6, 200916 yr Moderator click here for compatibility list try this site has helped me out a lot with swapping parts why are you answering a question from 2005? can you please see the sticky regarding sig size as its too big mate HERE
