August 26, 201213 yr cracker, Wheres you from,,? i was over Dukes pass today , 40 cormers in 5 mls , you been over it,,
September 6, 201213 yr Author Here is the cyclinder head removed and repaired ....Valve guide 6 and valve in cylinder 3 damaged engine stripped and valve guide renewed ...new valve ordered ....looking good
September 6, 201213 yr Author Here's the head with all valves except number 5 which is in number 6 valve guide to check clearance and seating...all good......new valve ordered will be used in valce guide 5 showing empty in this pic...ok thanks all
September 6, 201213 yr Moderator looks a good job too, how much did that set you back? must have been over revved if you can do that with rev limiters
