Hi
Can anyone tell me if the xz clutch is the same as the fz 600 are the same I have seen picks of the 550 clutch and they look the same but conformation would be good? I still have the clutch slip prob with the fz and new parts are so expensive I tend to look for a good alternative first
Thanks
Trev
The steel drive plates might be the same......but I'm not sure about the basket......splined hole in the center could be a different pattern :huh: ....assuming that the clutch dimensions are the same.
Seems a reasonable alternative, but you'd have to compare parts to be sure ;)
