August 18, 201213 yr Unfortunately got pulled over today whilst taking a pillion by the police because my indicators weren't working properly, apparently the back ones were dimming the brake light and were really dim.. Now they're not working at all! The only one that flashes properly is the right front one, left front one just stays light up and doesn't flash.. Is the battery just flat?? Please help!!
August 18, 201213 yr Hi Nathan, check your EARTH on the circuit and give it a clean, usually just crud and dirt that causes these problems. Also just the obvious check that the bulbs work?
