Lights just went out on my XS250 no idea , please help
pulled up went up a kerb my headlight went dim , then died completely , its a custom and i havent looked at it yet , is this serious , the brake light still works when the levers are activated but no running light when there not , and the speedo light occsionally works , any ideas , iv checked all the connections the fuses and that could it be the reg rec or the switch also does anyone have a PDF of the wiring diagram and manual for an 84 yamaha xs250
you need to double check them wires,
gunna be somat simple , when u went up the curb it proberly popped a conector if ur gettin dim and intermiternt lights then its prolly on the earth side check connectors inside the headlamp shell
