sprocket modification
Sorry for not searching the forum but I'm using my phone, no access to a pc.
I want a blue sprocket and chain for my bike, it's just had a new one but I want a blue one now.
What is the difference between DID & O Ring?
And
For more acceleration do I need more or less teeth on the sprocket, does this apply to the front sprocket as well?
I want a blue sprocket and chain for my bike, it's just had a new one but I want a blue one now. Why boather, the chain will be black with oil in no time.
What is the difference between DID & O Ring? O ring chain has little o-ring's on it, helps keep grease in the rollers.
And
For more acceleration do I need more or less teeth on the sprocket, does this apply to the front sprocket as well? leave the front alone, at the very most go 1 tooth more on the rear, you will kill your engine with revs otherwise.
Paul there's plenty of coloured sprockets on eBay, it's just a case of trawling through them all.
2 Wheels when you put it like that you have made me realise how pointless a coloured sprocket
and chain would be. It would be black bright after two days. I think I won't bother now.
