RIrons Posted August 14, 2012 Posted August 14, 2012 Can anyone please advsie where I can get hold of the 2 small round seals that go betwwen the 2 halves of a 2 piston caliper, they seal the fluid track from one half to the other. Searched the i'internet and can't find anything as yet.
YPVS TONE Posted August 14, 2012 Posted August 14, 2012 I know they are not listed on the parts lists as Yamaha didn't recommend you split the calliper.
Moderator drewpy Posted August 14, 2012 Moderator Posted August 14, 2012 can you not measure and get an O ring to suit?
Moderator Cynic Posted August 14, 2012 Moderator Posted August 14, 2012 Have you tried the actual 350 owners club. I know they have remanufactured some of the harder to find parts.
RIrons Posted August 15, 2012 Author Posted August 15, 2012 Cheers guys, I had thought of O rings, jsut concerned with the brake fluid attacking them, I'll try the 350 club. I also know you shouldn't split them. but without doing so the pistons were never coming out. They had been very badly kept. I have the originals so they may reuse.
YPVS TONE Posted August 16, 2012 Posted August 16, 2012 Found these on ebay. Worth phoning to see if they are compatible with the F2. http://www.ebay.co.uk/itm/2-caliper-joint-seals-RD350-YPVS-RGV250-/160669165248?pt=UK_Motorcycle_Parts&hash=item2568a0e6c0 Tony
RIrons Posted September 6, 2012 Author Posted September 6, 2012 I have now found a full set of seals and joint rings from Powerhouse, you can use the RGV250 ones but they retails at 5 or 6 quid from a suzuki(wash my mouth out) dealer, half that price at Powerhouse. Thanks for all the suggestions
Moderator drewpy Posted September 6, 2012 Moderator Posted September 6, 2012 I have now found a full set of seals and joint rings from Powerhouse, you can use the RGV250 ones but they retails at 5 or 6 quid from a suzuki(wash my mouth out) dealer, half that price at Powerhouse. Thanks for all the suggestions that's good to know as I'm sure they share the same calipers as the FZ600 I have
