Posted August 14, 201213 yr Can anyone please advsie where I can get hold of the 2 small round seals that go betwwen the 2 halves of a 2 piston caliper, they seal the fluid track from one half to the other. Searched the i'internet and can't find anything as yet.
August 14, 201213 yr I know they are not listed on the parts lists as Yamaha didn't recommend you split the calliper.
August 14, 201213 yr Moderator Have you tried the actual 350 owners club. I know they have remanufactured some of the harder to find parts.
August 15, 201213 yr Author Cheers guys, I had thought of O rings, jsut concerned with the brake fluid attacking them, I'll try the 350 club. I also know you shouldn't split them. but without doing so the pistons were never coming out. They had been very badly kept. I have the originals so they may reuse.
August 16, 201213 yr Found these on ebay. Worth phoning to see if they are compatible with the F2. http://www.ebay.co.uk/itm/2-caliper-joint-seals-RD350-YPVS-RGV250-/160669165248?pt=UK_Motorcycle_Parts&hash=item2568a0e6c0 Tony
September 6, 201213 yr Author I have now found a full set of seals and joint rings from Powerhouse, you can use the RGV250 ones but they retails at 5 or 6 quid from a suzuki(wash my mouth out) dealer, half that price at Powerhouse. Thanks for all the suggestions
September 6, 201213 yr Moderator I have now found a full set of seals and joint rings from Powerhouse, you can use the RGV250 ones but they retails at 5 or 6 quid from a suzuki(wash my mouth out) dealer, half that price at Powerhouse. Thanks for all the suggestions that's good to know as I'm sure they share the same calipers as the FZ600 I have
