Check your splines or risk a costly repair!!!!!!!
Hey guys - if you've got a loose gear level, kick start etc do yourself a huge favour and tighten it up correctly before you ride again.
If you strip a spline on an engine/gearbox shaft get ready for a nasty ££ surprise and a load of agro :sigh2: .
Some of you may have seen or even bought a bike where the problem has been 'fixed'/bodged' by welding the lever to the shaft - the problem then gets worse when there's an engine casing that needs to come off.
My old TY had a loose gearlever because it couldn't be tightened up anymore as the pinch gap the alan screw tightens had fully closed. This is an aftermarket lever - not uncommon on off road bikes as its one of the first things to get mangled.
Easy fix though - removed the alan screw, shoved the gear lever in the vice to close the pinch gap then used a fine bladed hack saw to enlarge the pinch gap by about 1mm.
Back on the bike for a snug fit on the spline.
Happy Days!
Jim.
