Posted August 6, 201212 yr Helo to everybody. I`m new member of this forum, and this is my ride wich I own for more than 10 years
August 7, 201212 yr Author Hi Sacha Well fun ride turned to extra fun when original DT 50 R engine fail. So I decided to swap with RD 80, wich has 6 gears, and is a lot faster. But fun ride turned into bad ride when the kick start shaft break at 2 peaces, and engine could not be runned. Since then I my motorcycle is staying in garage and I`m looking for some solution. Can I found somewhere complete kick shaft with sprocket and spring? DT80 and RD80 are two identical engines.
August 7, 201212 yr Hi welcome try re posting this in workshop might get better views not everyone reads these
August 8, 201212 yr Hi Sacha Well fun ride turned to extra fun when original DT 50 R engine fail. So I decided to swap with RD 80, wich has 6 gears, and is a lot faster. But fun ride turned into bad ride when the kick start shaft break at 2 peaces, and engine could not be runned. Since then I my motorcycle is staying in garage and I`m looking for some solution. Can I found somewhere complete kick shaft with sprocket and spring? DT80 and RD80 are two identical engines. You've come to the right place then. Take dt502001's advice and post your questions in the workshop. You're likely to get more help there.
August 8, 201212 yr Author Welcome, dzish" looks like a nice dry climate, ,, am envious ,, Yeah, here motorcycle can be riden 9 months in year... and I`m driving car at +40C, instead of motorcycle...
