ldeniro Posted August 6, 2012 Share Posted August 6, 2012 Hi Guys, I have read all over the net concerning this but am still facing some difficulties concerning problems with the Speedo. At first the speedo was not showing anything on the display and not even lighting up. A trip to the local bike shop told me that I needed a new one as the old one had broken. I decided to take it apart and just check the components to see whether any had burnt out but they had not. When I plugged it back in, it came up displaying the standard enduro and motard mode choice that everyone talks about. From reading other posts I attempted to set this to the correct mode a couple of times, but each time I tried this, the screen back light came on and '125' was displayed on the screen before it died again. I am just wondering whether anyone else has ever had this and in fact whether I do need to buy a new unit or whether the bike shop is trying to get me to spend £211.75 for no reason. Is there a certain type of programing that I have to use or could this be a connection fault on the bike. Any help would be appreciated. Thanks in advance. Link to comment Share on other sites More sharing options...
ldeniro Posted August 6, 2012 Author Share Posted August 6, 2012 Hi Guys, I have read all over the net concerning this but am still facing some difficulties concerning problems with the Speedo. At first the speedo was not showing anything on the display and not even lighting up. A trip to the local bike shop told me that I needed a new one as the old one had broken. I decided to take it apart and just check the components to see whether any had burnt out but they had not. When I plugged it back in, it came up displaying the standard enduro and motard mode choice that everyone talks about. From reading other posts I attempted to set this to the correct mode a couple of times, but each time I tried this, the screen back light came on and '125' was displayed on the screen before it died again. I am just wondering whether anyone else has ever had this and in fact whether I do need to buy a new unit or whether the bike shop is trying to get me to spend £211.75 for no reason. Is there a certain type of programing that I have to use or could this be a connection fault on the bike. Any help would be appreciated. Thanks in advance. Also just to confirm, the small square lights for the indicator signal and side/headlights are lighting up so there is contant power there. Thanks Link to comment Share on other sites More sharing options...
Prichard XT Posted August 13, 2012 Share Posted August 13, 2012 Its a design fault which yam dealers will fix within warrenty mines been rewired 3 times and the last time i rewired it, it wasnt the wirin loom it was the back of the key ignition the three contact plates were loose due the springs behind them lossin compression simple fix was to clean the contacts and strech the springs by 4 - 5 mm put back togethe in the right combo and it all worked iv got the same problem again dose only the green head light square and indicator green square work good luck let us know if ya find the fault Link to comment Share on other sites More sharing options...
Grouch Posted August 14, 2012 Share Posted August 14, 2012 Hi guys, I have the exact problem on my XT 125 X. It has been like that for months so I have just got used to it, but I'm getting it fixed so it looks like I need a brand new speedo. Link to comment Share on other sites More sharing options...
Grouch Posted August 14, 2012 Share Posted August 14, 2012 Your best off getting a new speedo Link to comment Share on other sites More sharing options...
dt502001 Posted August 14, 2012 Share Posted August 14, 2012 Just a thought if it is a reacuring problem would it not make sence to put on a aftermarket speedo Iv seen them around the 80 dollar mark(CANADIAN) Link to comment Share on other sites More sharing options...
Prichard XT Posted August 14, 2012 Share Posted August 14, 2012 Its a design fault which yam dealers will fix within warrenty mines been rewired 3 times and the last time i rewired it, it wasnt the wirin loom it was the back of the key ignition the three contact plates were loose due the springs behind them lossin compression simple fix was to clean the contacts and strech the springs by 4 - 5 mm put back togethe in the right combo and it all worked iv got the same problem again dose only the green head light square and indicator green square work good luck let us know if ya find the fault turned out that wasnt the problem for me this time checked the fuse battery and ground conections still nothing giveing a full system check ove the next couple of day can guarentee its a connection issue let ya know if i can pin point the problem give a proper solution with out spendin hundreds Link to comment Share on other sites More sharing options...
Grouch Posted August 15, 2012 Share Posted August 15, 2012 http://www.ebay.co.uk/itm/New-Motorcycle-Universal-Trail-Tech-Vapor-Digital-Speedo-Dashboard-Silver-/170852059567?pt=UK_Motorcycle_Parts&hash=item27c79389af I'm getting one of these and my bike is booked into the garage next week for it to be fitted. If the speedo is knackered replace it because all XT 125 X/R speedo's are crap, it's a common fault on them. Link to comment Share on other sites More sharing options...
Prichard XT Posted August 15, 2012 Share Posted August 15, 2012 that aftermarket speedo looks like a good option worth a try Link to comment Share on other sites More sharing options...
Grouch Posted August 15, 2012 Share Posted August 15, 2012 I'm buying one on Monday and getting it fitted Thursday. I will let you all know how it turns out. Link to comment Share on other sites More sharing options...
Prichard XT Posted August 15, 2012 Share Posted August 15, 2012 yeah man defo want to know looks an nice piece of kit just wondering does the old loom have to be modified to fit it ? Link to comment Share on other sites More sharing options...
Grouch Posted August 15, 2012 Share Posted August 15, 2012 No it has all its own sensors etc so you you don't need to connect it to the existing loom. Link to comment Share on other sites More sharing options...
ldeniro Posted August 16, 2012 Author Share Posted August 16, 2012 Thanks for your answers. I went with some advice from a local bike shop and brought a new speedo assembly. After messing about with Yamaha because they sent the wrong one initially, I have plugged the new one in to find that it does exactly the same as the old one. 125 flashes up and then a blank screen. Im now £220 out of pocket and the problem persists. If anyone has any other ideas concerning the wiring etc, please let me know, I would really appreciate it. Thanks in advance Link to comment Share on other sites More sharing options...
Grouch Posted August 16, 2012 Share Posted August 16, 2012 Thanks for your answers. I went with some advice from a local bike shop and brought a new speedo assembly. After messing about with Yamaha because they sent the wrong one initially, I have plugged the new one in to find that it does exactly the same as the old one. 125 flashes up and then a blank screen. Im now £220 out of pocket and the problem persists. If anyone has any other ideas concerning the wiring etc, please let me know, I would really appreciate it. Thanks in advance Like I said you need to buy the one I showed which does not connect to your existing loom. Link to comment Share on other sites More sharing options...
Grouch Posted August 16, 2012 Share Posted August 16, 2012 This is the one I am getting http://www.ebay.co.uk/itm/New-Motorcycle-Universal-Trail-Tech-Vapor-Digital-Speedo-Dashboard-Silver-/170852059567?pt=UK_Motorcycle_Parts&hash=item27c79389af It does not connect to your existing loom, it comes with it's own sensors etc. My 2006 XT 125 X is doing the exact same thing as yours. Link to comment Share on other sites More sharing options...
Prichard XT Posted August 17, 2012 Share Posted August 17, 2012 well well finally checked full system and nothing so last check was the speedo unit its self removed it from the bike as soon as i fliped it over i noticed an deformation of the casing (Not Good) soon as i opend here up there was one big burn mark across the board and one of the components litrally crumbled to ash I couldnt help but piss myself laughin gonna buy a second hand one for the time being and replace the lot like grouch Link to comment Share on other sites More sharing options...
Grouch Posted August 23, 2012 Share Posted August 23, 2012 I've bought the 'Vapor' model speedo from eBay. The shop was actually in my home city so I went to the shop in person. The speedo cost £92 and I need a mounting case which will cost approx £40, only they were out of stock. I'm waiting for the mounting to arrive then it's getting fitted by a mechanic. I actually had the bike booked in today to get done but I needed the mount as it couldn't be mounted to the original speedo as a temporary measure i.e cable tied because of the wires at the back of the unit. It is a magnetic piece that mounts on the brake disc. It is a really simple device so I could do it myself but can't be bothered. It will probably take an hour to attach. The speedo itself seems a bit plasticky and doesn't look like it would survive getting caught in a heavy downpour of rain. I suppose I can make a cover for it or something. The display light is blue. It has loads of functions but I will only use the speedo. Link to comment Share on other sites More sharing options...
