Posted May 14, 200520 yr Does anyone know the tyre pressures for a YZF750? A friend has my manual and I cant get hold of him...
May 14, 200520 yr Moderator If I recall correctly from this very question being posted before 33f/36r seems to ring a bell......but I'm sure that Alex or Beez will be along soon to confirm this
May 17, 200519 yr Moderator if memory serves me right, i used to run mine around 34/38 give or take a coupe of psi, anything around there will not be far off
May 20, 200519 yr [it depends on the type of tyres you have. different manufacturers require different pressures. i've got a mag with the different pressure/ manufacturers for most bikes, let me know and I'll send the correct pressures. ps the front should be 120/70zr17 and the rear 180/55 zr17.
