Vin/Serial location for newley aquired YZ
Hello, I've just aquired a 1989 YZ250W, the frame has been repainted and so I need to know what location i can find the VIN / Serial #s, also I know that WR means wide ratio, but when ther is no R , what dose just the W stand for?. Thanks Littleone.
Hi Littleone. You've posted your question in the wrong place. This section is just for help using the forum. :) you should really introduce yourself in the new member section first. Then post your question in the appropriate place (I'm thinking the workshop). I think the VINs are usually stamped on the headstock... don't know about the WR or W. Welcome aboard the YOC.
