Gas Sensor wiring
Ok. So i have a 1987 yamaha virago xv1100. I bought it from a friend. It does not have a instrument panel becuase his ex wife put a hammer to it. All the wiring is fine i just dont have a Nuetral light, a oil light and a gas light. So here we go.
I want to give myself a Gas light so i know when im low on gas instead of waiting for it to choke then switching it to researve. So i bought those Lights people use in sports cars as Clutch lights ect.
There is a green wire and a black wire coming from my gas sensor under my gas tank.
I took the green wire from the gas sensor and put it to the NEGITIVE to the light i installed
I took the black wire from the gas sensor and grounded it to a common ground.
I took the positive from the Light i installed and hooked it to a common positive of my lights. This way when i turn the bike on it gets power.
The light wont turn off.
Here is my wireing schimatics. Am i reading it Wrong? Did i do it right? anyone have any ideas
According to the wiring it says.
-Green to fuel warning light
-Black to the common ground rear left turn signal
-Positive from fuel warning light shared the positive to the oil warning light
Ok so i did some thinkg. I figured The light wont go off maybe becuase i have a BAD fuel sensor. Then said wait. Let me check something. I hooked my Electrical tester to the pisive side of the batter and negitive on the frame. Bam 12 volts so frame is ground. Put it on the gank. Nothing. Then i thought, Wait tank has paint so it wount work. So i put the negitive on my Gas tank CAP and BAM. volts..
That means my gank tank some how is grounded.
