DT 175 steering bearing issues ......aarghhh
This post is 4439 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Ok here we go
Yoke showing shoulder
Grease seal in place
Bearing in place
Cups driven in to shoulders
Top bearing in
Stem in
Top seal on
Drawn up with threaded bar
lock nut on
5-6 mm gap between top of stem and top of yoke.
I have just re fitted it with the old grease seal which has given me an extra mm or so, see image below
Link to comment
Share on other sites
thats not good! :eusa_think:
The castle nut should be pretty much filled with the stem thread
The old seal fits around the shoulder doesnt it, thats why you gan a bit extra there.
are both the new seals the same with the same sized holes through them?
of course if you rough it together with no seals you should have lots of stem thread available...if not then the bearings are no good! ?
Link to comment
Yes you are correct the old seal fits around the shoulder but omitting both seals only gains me about 2mm
I have tried the seals every which way even the wrong way up :eusa_whistle: the holes are the same size.
Think I am going to order some more bearings, can you recommend a supplier I was going to go through Yambits
Link to comment
by all means use yambits but why not ring them and speak to Dave (mr Yambits) talk to him about all the issues you are having with this
Link to comment
Well that's kind of a pisser isn't it? Isn't a reason behind getting the tapered ones to get away from the older style? Hmm I hope I don't run into that. :shakeno:
Link to comment
  • 3 weeks later...
Hi, yeah all good. after assembling and disassembling it so many times the whole thing went together in about 20 minutes. came across another issue (see topic - front wheel alignment)
set out for its mot last Saturday but the gear shift pedal broke before i got to the end of the road :eusa_doh:
fingers crossed for this Saturday
Link to comment
I have the top and bottom yokes of a ct1 if they fit? in good nick if any use.They were not on taperd bearings but i beleve you can fit them .Looking at your pics the replacement bearings look wrong anyhow good luok i am only near crewe if you need the bits Ian Edit i see the problems sorted..
Link to comment
  • Recently Browsing
