DT 125 Electric nightmare
My DT was butchered by the previous owner who re sprayed the frame then had no idea how to re-wire it :madflame:
I have most back in place bar a group of wire at the rear....im missing the side stand switch and the relay at the expansion bottle. Also I can see a block connector with black & orange wire coming out at the battery...(not to be confused by the other near the cdi which is on the oil tank)
I've managed to get a neutral and oil light on the clocks but I cant by pass the side stand or neutral relay because I cant get a decent diagram.
Engine code starts with 4BL if that any use to anyone. Ill post plenty of pics of ignition down to rear on monday :thumb:
