RS100 ('78 1Y8) - Clutch catches late
Hi y'all,
Got a question concerning my clutch.
It catches very late, and the screw on the lever is at max tension.
Are my clutchplates worn out?
Thank you. Rik.
Yes indeed.
You are right. Adjusted it, and is a little bit better. But still think the clutch has had it's best days:).
On your lefthand-side there is a cover at te bottom which hides your dynamo/alternator.
Behind the cover there is a bolt. FollowIng the Haynes manual there is a possibility to adjust the clutch.
Rik
