Yamaha RXS 100 break light won't disengage
Hi I'm struggling to sort this problem. The break light is on constantly- (unless I remove the earth spade from behind it, then the rear light filament comes on.) I've removed the break switch and the light stays on. Ive tested the switch and it appears to be working. But it's disconnect to count it out. Can anyone suggest anything- is it a case of checking wiring?
