Posted July 18, 201213 yr Hi, I need a bit of help or advise with my Yamaha YBR125 as I have a small problem with either the clutch or gearbox. The problem is when i shift up or down some times the bike seems to slip into neutral and the revs shoot up, I then struggle trying to get it back into gear as it refuses to click and acknowledge a gear and seems to stay in this false neutral for a bit, usually it clicks out after a bit and jumps into gear but on some occasions I have to pull over and stall and bump start it. Can someone please give me a bit of advise or support as I am a learner and Im not sure whether it is me doing something wrong or the bike is damaged. Thanks.
July 18, 201213 yr Hi, before anyone will give you any help you will need to just write a brief introduction about yourself in the relevant section.
July 19, 201213 yr or you could just search the forums - there has been loads of discussion about this
