Wider rear rim FZR 1000 1988
Hi guys.
I have a little project with my old bike - Yamaha FZR 1000 from 1988. - I wont a 180/55/17 tire.
Standard rear rim is 18 x 4,5. I have bought a rim from a 3LE model which is 17 x 5,5.
Problem: Standard rear axel is 17 mm (diameter) - new is 20 mm. No bearing combinations posible.
So I am wondering, if it is posible to use a swingarm from the newer model 3LE - about 1993 - to get the
thicker rear axel. Does such a swingarm fit in the frame, and what about the chain alignment ?
Does anybody know something about this ?
Thanks
Morten
Hi Morton not sure about fitting a new arm on but your opening a big can of worms, steering head angel is going to change with a smaller dia. rim.
Anyway thats yours to fix But you should take a min and introyourself in the new members section it only polite to know a bit about who your talking to
Hi dt502001.
Yeah I am aware of the worms, maybe I can use them as bait to solve my problems :-)
Well lets see how it changes to better or worse - if I can get it to fit.
I have written a short intro in new members and even put a photo on my profile, so thanks for the advice.
  • 5 years later...
Would be interesting to know whet you ended up doing.
What I did with mine is fit a swing arm, fork and wheels of a Suzuki Slingshot, makes it easier to fit larger wheels, can run a 190 in the rear without any issue, and extends the rear wheel a bit so can put a bit more traction to the road. Also fitted a R1 tail section.
Damn, its 5 years old. He only made 3 posts so a reply is long past coming.
  • Cynic locked this topic
This topic is now closed to further replies.
