July 5, 201213 yr Hi there. After spending a month of working on my TZR after work I still can't get it working. I'll start from the beginning. On the way to work in the morning I was just doing 40 mph ( not revving the nuts out of it. ) and after I changed into 6th it just seemed to loose all power. I knew the engine was gunna die so I pulled in the clutch just incase the rear locked up. So I pulled to the side and just had a quick scan over it. It wasn't too hot, everything looked still attached and as if it should be working. I tried starting with the battery with no luck so resorted to bump starting, again with no luck. But it made no noise lick as if it wanted to start. There was no ignition of the fuel what so ever. I've cleaned the carb with help, changed the spark plug, tried new top end gaskets, but they were the wrong size. I've checked there's a spark but still no start. Has any one got any suggestions as I'm desperate to get back on the saddle
July 5, 201213 yr Moderator so theres a spark? is fuel getting to the plug? is there compression? have you ever had the magneto flywheel off?
