July 3, 201213 yr hello all.i have recently purchased a dt125x i want to rebuild the top end as i do not know when it was last done and the bike has now done 16,000 miles.on the side of the top end it says yz.i want to know if they all say this or has somebody changed the top end with one off a yz bike???
July 4, 201213 yr Author HI I AM AWAY FROM HOME AT THE MO BUT WILL POST A PIC ON WEEKEND.CHEERS FOR TAKING TIME TO REPLY
July 5, 201213 yr It's an interesting one there airhead. I'm still confused by the "Y codes". I have a 3mb that's y-1 but another that is y-3. I also have 3bn y-3 y-4 and y-2. My 3mb barrels appear to be y-1. I have a 3bn barrel but can't remember what y code it was.
July 6, 201213 yr Author thanks guys looks like airhead is correct it looked like yz at a quick glance but it is actually Y-2.it also has 3MB on the head like the one in the pic above.can i take it my engine has a standard size piston now as i want to get a new one also what is a good make when it comes to buying new pistons thank
July 6, 201213 yr Moderator you would need to clean the top of the piston to see the size that is currently fitted...dont take it for granted that it it is currently fitted with a standard piston
July 6, 201213 yr Author ok i was going to measure the bore with internal micrometer.will i need to buy new head bolts and other bits i have got gasket kit i just want to be able to do the change in one day without finding out im missing something .thanks again
