wiring sat nav on xvs1300
Hi, has anybody fitted a sat nav to a xvs1300 and where did you tap into the electrics, all info greatly appreciated, ta
I wired a Garmin Zumo 660 to the XVS 950. Its wired in to a positive that is only on when the power is on. It then has its own fuse. It is also wired to the autocom.
I ran a wire from the battery (via fuse) under the tank and installed a waterproof cigarrette socket under the throttle side neck cover, When the cover is on you can't tell its there. I might have a pic...
