June 26, 201213 yr Hi, I have a problem with my AT3... I tested the spark plug to see if it gives off a spark. I also took off the connector but no luck here as well. The next thing I guess is to thest the coil. How do I do that? Do I need to yake it off the bike? the Cables seem to be soldere on... Thanks for any advice, Nilzor
June 27, 201213 yr Author yes, i also held the end coming from the coil against the engine to see if there's a spark there
June 27, 201213 yr if you can get a similar coil off another running bike and try that for spark or yours on another bike.
June 27, 201213 yr Moderator you can check the resistances of the ignition coil and the field coil, the figures are in the parts book PM sent
June 28, 201213 yr Author Thanks all, By now the battery completely drained. Would that have an impact on the ignition? @blackhat250 What do you mean with Mag cover, like the flywheel?
July 10, 201213 yr Author is there a chance that it doesnt work without the original key? I can put another key in and change the position of the ignition. However the key is kinda loose in there...
July 10, 201213 yr As long as the ignition is on, you can disconect the black/white wire to iggy switch & handlebar stop , this should give you spark, ,
