deza68 Posted June 26, 2012 Posted June 26, 2012 Hi all was wondering if some one could give me some advise as to the ideal tyre pressure with a pillion on, i'm using stock tyres at the moment got front set for 33lb and rear for 36lb but just doesn't feel right
Noise Posted June 26, 2012 Posted June 26, 2012 How you mean by its not feeling right? guess you have not been given the bikes hand book? it should be in there. im at work so cant check for you.
Ttaskmaster Posted June 26, 2012 Posted June 26, 2012 IIRC, the manual says, for a standard bike with no pillion: F - 28psi R - 32psi However, check your tyre manufacturer's recommendations as these will be more applicable to your specific setup and are often very different to the manual.
Ttaskmaster Posted June 26, 2012 Posted June 26, 2012 Edit: Manual actually says: F 2BAR R 2.25BAR for up to 90kg F 2BAR R 2.5BAR for up to 180kg Again check your specific manufacturer's recommendations Chances are you'll be better off upping the shock absorber. Also, if the combined weight of you, the pillion (including clothing) and any luggage is more than 180kg (200kg for the Classic) then you're overloading the bike and straying into dangerous territory.
PeterC Posted June 26, 2012 Posted June 26, 2012 My manual for my 2007 650A and Dunlop D404F front / Dunlop D404G rear up to 90kg load - 33 front (225kPa) 33 rear 90 to 198 kg load - 33 front 36 rear (250kPa) no idea what that is in BAR As said above you may need to adjust the rear shock - it has numbers from 1 - 7 with 1 being soft, 3 is standard, and you can work the rest out I'm sure. Just remove the seats and adjust with the wrench and extension bar in the owner's tool kit.
Noise Posted June 26, 2012 Posted June 26, 2012 33 PSI is exactly 2.27 Bar 36 PSI is exactly 2.48 Bar Not that im in any way a pressure geek i just have a very good converter on my works PC lol
