2001 dt 50 voltage regulator
Can anyone help me identifie the terminals at the voltage regulator on a dt 50 1991
I am restoring one back to be road legal,the previous owner felt the need to cut out all the lighting wireing.
I have followed the factory wireing schematic rewired the entire bike(signals head/tail,horn) all is working.
The problem is that the schematic does not show where the feed from the stator( 2 wires I white and 1 yellow/red striped) would be located..or where the positive and negitive termnals.. on the v/r... it's brand new and if i hook it up wrong it will blow.
If anyone knows someone with one and can get a look under the gas tank where the V/R is mounted and tell me the location of the black and red the other 2 have to go to the rectified side of the regulator.
So to help make this simpler the V/R is on the right side of the frame the way I look at it ..and the red and black would be???? top or bottom frame side or tank side.
Hopefuly some can answer this as it is the last thing to do get riding this bike .
Thanks Phil
Well I decided to fuse up the positive terminal with a .5 amp fuse (after using my multi meter set in diode mode to find the positive and neg terminal of the V/R) and just hook it up.
The .5 amp did blow when I hooked up the battery I had the neg and pos backwards so I switched them put in a new .5 amp fuse and hooked up the battery :eusa_pray: sucess.All went well and the bike is running and charging now the fuse has been upgraded to a 30 amp
I posted this just so anyone working on something and unsure which is pos and which is neg just rember to fuse realy low and all should go well without blowin something expensive.
So we're off to the lake for some fishing,boating and beers Happy Canada day
Thanks..... aaaaa.. Airhead kinda a dumb title for a mod but if your OK with it ..Then I'm ok with it just here to learn and help whenever I can
Phil K
