TZR 125 2RH Carb rebuild
I am in the middle of rebuilding a 1990 TZR, I'm at the stage where I am reinstalling the carburettor. I am a bit unsure where all the hose go. Am I correct in saying that the main fuel line in goes in the connector that sits vertically on the left side of the carb? The oil line goes on the front right brass connector? There are 2 connectors ( one on each side which are horizontal ) are these breather pipes and do the hoses sit vertically downwards? There is another connector on the base to the carb, again another breather vertical downwards? The last connector is just beside where the carb joins the air box it is a white plastic connector that rotates, what does this connect to?
