XS250 Bobber
Twoesme
This post is 4350 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Bought this xs 2 weeks ago for About £250 with new tyres,She was rattling her nuts off (tappets) when i rode her home.
No front brake ,it was working but no bite on the disc
This was the state under the seat
Air filters were just as bad
I adjusted the zorst a bit
Chit or bust i went to work on her,Fixed the number plate down on the side and chopped the rear a bit and fitted cow horn style bars.
But it did,nt look right
More work to lift the zorst up
Starting to take shape
But still not right
So back to the frame
Getting there
Still that zorts don't look right
Nipped a bit more off it and fitted the rear muddy
That zorst mun .....
Right its having it
Thats the ticket
Front muddy
Lowering it more later.
Cleaned up the front pads and disc ,also drilled some pretty holes in it .
Now she stops .
Bit of rattle can paint with fleck ,single seat and home made panels
That zorst !!
Better seat and battery /wire cover plate
Got an oil leak behind the points on the cam seal .(the tic over lol) I advanced the timing ,and every other thing you coud do and its holding there at 2k revs but some times cuts out.used to it now .
Got some cone filters on they'r way.
new plugs/caps,she's had an oil change ,starts a lot better,more or less off the button now ,Rear shoes need changing next,Couple other jobs.
But she's on the road .
Zorst is now stone chip black,And i,ve added some black stipes to the panels.
She rides tidy,but reving hard say in 3rd onwards it holds at about 6k revs for a while then pulls through right up to the red line ,Just holds there at 6k for some reason ?
Plugs look a good color,Going to clean the carb out when the filters are back see if any jets are blocked and put an inline filter on.
Also got my eye on a 400 motor but it aint got no carbs ,So hafto find out if the 250 carbs will work and if the down pipes will bolt straight on.
Oh ! That zorst :D
Ps how's Yamhead getting on ,I heard about his nasty crash if its the same Yank scott I know ....
Looking good, the fuse box made me laugh =)
those fuses are wicked! :babyha:
there are drill patterns out there if you wanted to drill more evenly spaced holes in your disks. (i know bit late now)
get the 400 engine in there as they really motor up to 90.
i admire what u have done and top job! but if it was mine and i was doing it, i would of gone for the cafe racer look rather than a bobber.
either way nice job hope you enjoy it :)
  • 3 weeks later...
Do not understand what the problem with the fuse box is ????
It has one fuse as an example and the other 3 are the uprated version..
could be a safety feature,,, If any of them blow you at least know you have a SERIOUS
problem and not just a little niggle
