2001 DT125r won't go over 55mph
I have a 2001 DT125r with just over 6000 on clock. I have changed exhaust to full 'big one' system, changed spark plug, new air filter, open power valve, located reed switch and taped it up, new battery and acceleration is loads better but still won't go over 55mhp, any help or ideas
Many Thanks Ben.
i have a w reg dt 125 with elec power valve. did you find changing the battery made much of a diff cos im thinking of doing this. also will my bike have that reed switch if its older than urs? also did that switch make much diff
Changing battery, plugs and filter feels alot better, you can hear it run better, I'm not to sure about the reed switch I think I've done mine wrong ( if that was the reed switch I taped up) will need to take another look. Need help or advise for my reed switch if anyone knows ????
