June 10, 201213 yr the exhaust on my rxs100 isn't the original. I took it off this weekend to look at decarbing it with caustic soda. the baffle was in really tight, but managed to get it out for the first time. The baffle is totally different in style to the one pictured in haynes and has not packing on it. I've read that some baffles don't have packing and I've also read that not having the packing doesn't effect performance or noise level so is not worth replacing. my question is how do I know if this style of baffle needs packing? anyone got one similar. took a pic here:
August 11, 201213 yr is the baffle drilled with holes along the full length of the baffle or mostly in the top section? i cant run mine at all with baffle packing i took the packing off and it was louder but i was able to top out in the red with my rpm.
August 11, 201213 yr that is the correct baffle pictured for RXS 100 , if you think about it it was difficult to remove , so how could you possibly fit it with " packing" ?
