Starting Problem
Hi, my boy has a YQ50 Aerox and had to have it brought back home on saturday on the back of the lorry.
It was running fine, it has got a 70cc mollossi kit on it and all the rest of the things to make it go fast but i can not get it to start.
I have a good spark, i have fuel getting to the carb, but the spark plug does not seem to get socked after kicking over!
With further investigation i took the air filter off and it feels to me that it is blowing instead of sucking which lead me to the reeds...1 side was not seating and i cannot get it to seat...is it possible the block has deformed? anyway found another block which looked fine but still cant get it to fire.....any idea's?
Thanks Andrew
PS the bike is a 2005 model with water cooling
Andrew, first things first i must say that i'm not familiar with the scoot..,.but
is there plenty of fuel in the tank
i assume the fuel supply is vacuum operated?...if so check the vac line from the inlet manifold to the fuel supply tap, see it hasnt come adrift, split, kinked etc etc
No no pipes split that i can see and yes full tank of fuel, i have had the carb off and cleaned and there is a new plug in it.
Fuel is getting to carb chamber just not getting to piston!
no nor do i!!!!
What is making me think is the fact that if i pull the air filter off and put my hand over the end it feels like it is blowing not sucking
the chamber at the bottom of the carb has a pipe connected to it that is a drain...pushing it in allows the fuel to drain..so therefore there has to be fuel in carb
Try the fuel directly into the cyclinder, it should start for a couple of seconds. At least you know the cylinder side of things is fine if it starts.
My sister has a Gilera Dna and had a similar problem to this. I ended up completely stripping it and it turned out the vaccum hose had slightly melted on the exhaust so the fuel wasnt being sucked through properly. The fuel line had fuel in it going to the carb but because there wasnt enough of a vaccum there wasnt enough being drawn through to run the bike.
Hi,
Had a new piston kit fitted it was the rings melted to the piston and lost compression.
Now done that and bike ticks over fine but when riding at 20mph+ it starts to hunt bad if u try to keep it to a constant speed. It will accelerate to good speed but continues to hunt.
Any idea's anyone?
Thanks
Andrew
