dtr wire mod
does it matter if you earth the green and black wire behind the speedo clocks on the dtr 125x to the frame or battery or is it to the frame only
i earthed mine to the bottom fork yoke just below my headlight, i've had no problems atall
One you earth it to something metal,, or scratch the paint off any bit of the frame so it shows metal then you should be ok
