Posted April 16, 200520 yr hi just wanted to know what the diffrence is between car oil and bike oil (motor)? there must be a diffrence or why would they sell to 2 diffent types...apart from the money aspect. many thanks j
April 16, 200520 yr Admin Yep there is big differences even though they still lubricate, i read a very intersting article from mobil on this on the net, but cant remember where. I seem to remember the clutch was the main thing
April 16, 200520 yr Author ← HEY. if i though it was stupid i wouldnt of ask .....would i??? if your so knowledgable what is the answer to my question??
April 17, 200520 yr Admin Right heres my stab at it then! Cars compared to bikes demand long service intervals so the oil has to be designed for this. The oils therefore have friction-modifiers and other additives in to keep them working for a longer time If you use car oil in your bike, the friction-modifiers cause a problem because most motorbikes have a wet clutch. Car oil gets onto the clutch, the friction-modifiers get to work and you'll end up with a slipping clutch. Bike oil doesnt have friction-modifiers, so you dont get this problem. Im pretty sure but oils for wet clutches have an MA label on it. Another thing to consider, is that car oils are not designed for a gearbox. The meshing of the gears shears the oil which does not happen with a lovely smooth crank. Which causes car oil to foam, losing its lubrication. Motorbike temperature flucuates a lot quicker than a car. Larger mass of the car engine combined with the larger amount of fluids and a sealed engine bay mean the temp changes are less pronounced. The higher power output of a bike engine compard to size means higher temps with less fluids and metal to absorb the temp change, causes rapid change in temp during operation. Which means the oil needs a better temp tolerance to cope with this. Finally car oils tend to be very thin and will burn off and some may get past the rings and burn off. And on top of all this a motorbike revs 4 times higher than cars. This site gives good info regarding oils http://www.chris-longhurst.com/carbibles/i...eoil_bible.html
April 17, 200520 yr Chip, there are some twit's who are slowly creeping into this forum like Vin Diesel and Eddy Irish. We need a admin tick box where we can just block there posts , or an individual one would be cool.
April 17, 200520 yr Author hi alexasigno....many thanks for your reply i think i know what you mean and i now know not to use car oil as i was tempted a little. smitty...glad you share the same feeling...tick box would be a good idea but it might get abused. ta to all J
April 17, 200520 yr Admin No probs mate, hope you understand my waffle. As for a filter maybe a gun would be better
April 18, 200520 yr HEY. if i though it was stupid i wouldnt of ask .....would i??? if your so knowledgable what is the answer to my question?? ← It would of been stupid not to ask.....
April 19, 200519 yr smitty...glad you share the same feeling...tick box would be a good idea but it might get abused. Nah an individual list, in your account you have a list of names, so when the page get's displayed it checks to see if there's a match. if so then dont show that post. It would be weird cause people would be replying to things that u havn't read. So then u might need a thing to temporaly turn off this thing. Just an idea. Thinking of writing one of these fourm thingies next semester.
April 20, 200519 yr I know, very big job. but it's one that ive been thinking off for a while. It's for an assignment for a web application class that i'm taking next semester. Done alot of programming before but sever side is new to me, ive done a bugger load of client side, both web (html + javascript) + run of the mill programs(c++, java etc).
November 10, 200519 yr the two oils car and bike are designed to run at different tempratures' and there are different types of cleaners and de' clogging ingredients between the two types. bike oil usually has to work a lot harder than car oil so is better refined and so costs more.
