May 29, 201213 yr I have a motoplat electronic ignition on my 76 dt 250 I have pushed it up n down the garden n can't get a spark I can't kick it over as I don't have kickstart mechanism anyone know how I can check to see if its the coil or the electronic part that replaced the points thanks
May 29, 201213 yr Moderator you can check the resistance of both the ignition coil and the magneto source coil, I expect the figures would be in the manual
