Posted May 29, 201213 yr hey all!! new to this and kinda new to bikes... have a late 80's xt350 with the xt350h engine... it's seems to bog out at about half throttle in each gear... picks up a bit then bogs again!?! any suggestions? any ideas where i can find an online shop manual for this bike??
May 29, 201213 yr You certainly are lost, you should have carried straight on past the bar, through general and yamabyss and continued until you got to the workshop section. While your'e here you might as well introduce yourself first.
May 29, 201213 yr Welcome backnaction" sounds like carb problem, or air leak ,,, more info required ,,, in workshop As he says,,,
