May 18, 201213 yr 15% OFF all 10w-40 Bike Engine Oils - USE VOUCHER CODE : BIKE ** Limited Time Only ** We have over 25 10w-40 engine oils available from the following brands: Amsoil, Castrol, Mobil, Moutul, Red Line, Shell and Silkolene Make sure you enter voucher code BIKE at the checkout to get your additional 15% OFF. As always, our expert advice is free. If you need help you can call on 01209 215164 (Option 2), email us at [email protected], or just ask here. Cheers, Oilman
May 18, 201213 yr I see the barrel pice has dropped to $ 96. A barrel,,, it was at $135 i make that a 30% drop ,,,, bet fuel never drops more than 5%,,,,,,and oil on shelf never drops,,, Can we have a answer,,,[ political probably, = riddle]
May 25, 201213 yr Author Offer still going, but not for much longer! Check out these prices with the voucher code BIKE applied: Silkolene Super 4 10w-40 semi-synthetic 4-Stroke Motorbike Oil 4 Litres: £20.40 1 Litre : £5.46 Castrol Power 1 4T 10w-40 semi-synthetic motorcycle 4 stroke engine oil 4 Litres: £29.50 1 Litre : £9.19 Amsoil 10W-40 Synthetic Motorcycle Oil (MCF) 1 Us Quart (0.946L) : £11.09 Silkolene Comp 4 10w-40 Synthetic Ester Based 4-Stroke Engine Oil For High Performance Motorcycles 4 Litres: £29.20 1 Litre : £7.56 Castrol Power 1 Racing 4T 10w-40 fully synthetic 4 stroke motorcycle engine oil 4 Litres: £38.93 1 Litre : £10.76 Motul 300V 4T Factory Line 10W-40 Racing lubricant for race bikes 100% Synthetic 4 Litres: £38.54 1 Litre : £10.32 Motul 5100 4T 10W-40 High performance lubricant for bikes Technosynthese – Ester 4 Litres: £23.40 1 Litre : £6.53 Other bike products on offer can be found in our Oilman's specials found HERE > > > As always, our expert advice is free. If you need help you can call on 01209 215164 (Option 2), email us at [email protected], or just ask here. Cheers, Oilman
