Is the clutch push rod the same on a '81 125 DX and a 200?
Yeah, these bikes are probably getting harder and harder to get anywhere with. I'll mail Yambits tomorrow and ask if they know.
Unfortunately they don't seem to have anything for the 125 DX.
Iknow of a RD125 owner ,i will enquire,, :eusa_think:
Airhead, thanks! I'll see if I can get my butt in there after the weekend, which is crazy busy.
Blackhat250, that would be brilliant, thanks! Like your tag, btw. I weigh around 100 kilos (mostly muscle, but a bit of the biker airbag), have a shaved head and a fist long Harley beard, and people allways ask me if I ride a Harley, and I always answer: "No, I do not have that much time to spare!" ;)
I can measure mine (rd 200 dx 1e8) if you like its in bits at the moment so full length up to the preasure plate is no trouble to do.Let me know if your not already sorted.
I'd appreciate that, thanks! :)
Hi
I have 22cm to the ball bearing on the first rod then 4cm to the flat end in the preasure plate on the smaller rod.I have not added the bearing into it as i think it would be added or subtracted by normal adjustment. Hope this helps..
Thank you very much! I'll compare that with the one I have. I appreciate the help.
