May 10, 201213 yr I want to change the push rod on my son's '81 125 DX (cast wheel), and I have found one at Yambits which is for "RD200 & DX 1973-1981". Would that be the same as on the 125 DX? I know they share a lot of parts, but not which ones. http://yambits.co.uk/rd200-clutch-push-rod-p-12666.html?osCsid=dl85ndmjgvuehq35v3ssih8gi1
May 10, 201213 yr Author Yeah, these bikes are probably getting harder and harder to get anywhere with. I'll mail Yambits tomorrow and ask if they know.
May 10, 201213 yr Moderator yeah let us know how you go on maybe you could trawl the cmsnl site to compare numbers?
May 10, 201213 yr Moderator another option is to ask on the aircooledrd club forum http://www.aircooledrdclub.co.uk/forum/default.asp
May 11, 201213 yr Author Airhead, thanks! I'll see if I can get my butt in there after the weekend, which is crazy busy. Blackhat250, that would be brilliant, thanks! Like your tag, btw. I weigh around 100 kilos (mostly muscle, but a bit of the biker airbag), have a shaved head and a fist long Harley beard, and people allways ask me if I ride a Harley, and I always answer: "No, I do not have that much time to spare!"
May 11, 201213 yr Moderator ....................people allways ask me if I ride a Harley, and I always answer: "No, I do not have that much time to spare!" great answer
May 18, 201213 yr I can measure mine (rd 200 dx 1e8) if you like its in bits at the moment so full length up to the preasure plate is no trouble to do.Let me know if your not already sorted.
May 19, 201213 yr Hi I have 22cm to the ball bearing on the first rod then 4cm to the flat end in the preasure plate on the smaller rod.I have not added the bearing into it as i think it would be added or subtracted by normal adjustment. Hope this helps..
May 21, 201213 yr Author Thank you very much! I'll compare that with the one I have. I appreciate the help.
