CT2 175 light issue
Hi All, I hope someone can help me fix the electrical problem with my CT2. Brakelight works fine if I leave he headlights off. If I turn them on, brake light is permanently on and the other filament in the bulb glows faintly when I apply the brakes. Any idea what could be wrong?
Thanks,
Adil
Hi Adil
I would check all of the rear tail light connections it looks like you could have a bad earth/ground connection and the electrickery is finding its own path to earth/ground.
Thanks, I will check for that.
Adil
