rxs100 1996
Bought this bike on Saturday without knowing anything about bikes, just passed my CBT and loved the look of this bike so much that I had to get one.
As I didn't know what I was doing its been a steep learning curve. This morning I didn't even know what a carburetter was.
here's a list of repairs/issues I think I've identified:
Fuel tap does not fully shut off
fuel line leaking - temp fixed and ordered replacement
carb overflow does not stop leaking fuel
no air filter
air filter housing has had hole cut into it - ordered replacement from a breaker
rust/ dirt in fuel tank
revs 3000 at idle - resolved
oil tube that goes to carb was leaking - fixed this
apart from whats listed above seems ok.
nearly there now I hope,
New fuel tap, fuel line fitted
carb cleaned - now its clean and with new fuel tap seems to only overflow if tap is left on, will keep an eye on this
replacement air filter box installed (from breakers)
rust/ dirt in fuel tank - I'm using hammerite rust remover
revs 3000 at idle - resolved now at pretty constant 1500ish
waiting for filter element to arrive and need to put gas tank back on tomorrow.
after all this lot should be ready to rock and roll.
