Aerox oil seal replacement
Took the aerox for its MOT the other day and It failed due to the fork oil seals leaking, I would replace the things myself but for some reason I apparantly need a special T holder to remove the cartridge and this costs about 60 quid, Is there any way I can change the oil seals another way? Cheers
Looking at the manual the forks look pretty conventional with the only tool you need is to hold the damper rod while you undo the bolt at the bottom of the forks.
Tony
