  • Replies 46
  • Views 9.9k
sorry to go off topic but i'm having a similiar problem with my carb, it seems to leak bits of fuel from the overflow, will gentle taps be worth a try for me? only happens now and again though and runs perfectly,
Keiran95, have you tried cleaning it out? may help. Mine was leaking all the time, however what really stopped it was servicing/ replacing the fuel tap. Mine sometimes leaks a very small amount, but only if I leave the tap on.
poke something down the hole through the outer case as well to find the depth and fit a screw 5mm shorter than what you find
thanks Airhead, another top tip. Got the new bolts on and adjusted the clutch, also changed the oil, which was black and full of crap, so I guess it needed doing!
