May 4, 201213 yr where is the cat converter on the standard exhaust for the yamaha dtr 125x sm,i want to remove it.
May 4, 201213 yr Its in the expansion chamber, you have to cut open the exhaust to remove it and have it welded back together again.
May 4, 201213 yr Author Its in the expansion chamber, you have to cut open the exhaust to remove it and have it welded back together again. i forgot to add that the bike is an 07 plate,is the cat still in the expansion chamber on this year?
