May 2, 201214 yr Hi.. Ive just got an 1100 Dragstar, Its got a new battery but the engine really struggles to turn over when i try to start it..its almost like a flat battery effect but it does start and runs lovely when it does..Any thoughts?? Thanks .... Also when i put the bike on full right hand lock the engine stops. very odd.
May 2, 201214 yr hi jester, iif its a new battery, i would say its a lazy starter,[ worn brushes etc]. meter needed to check load when operated, ,,
May 2, 201214 yr Author thanks for that..i'll get it checked..i forgot another problem, when i put the bike on full right hand lock the engine stops...very odd
May 6, 201214 yr Check the wiring loom where it goes around the headstock and into the headlight. May be some wear on the inusulated wires, which is causing a short on full lock.
May 6, 201214 yr Could be a laxy starter with worn brushes, what mileage has it got?... my first check would be the earth from the starter motor or the starter relay as a bad earth could easily cause high resistance and lead to a reduction in circuit performance The cutting out sounds a lot like wiring loom, check where the wires go through the headstock as often these turn into plastic plugs which can become loose over time and unplug themselves when you turn to full lock as the wires tend to pull apart, my old DT was the worst for doing that
May 8, 201214 yr Author turns out its my starter clutch.....only had the bike five minutes and its going to cost me over £600 to get it fixed..gutted..
