April 30, 201214 yr Good evening all, Hope somebody can be of some help. My XVS125 is what I can only describe as being clunky when I slow down. I dont have to be on the brakes or in gear for it to be like this. Recently had the usual on the service sparks air filter oil filter chain/wheel adjustment I cant feel anything when riding just when slowing down. Any thoughts appreciated. Steve
May 1, 201214 yr Author Not when applying the brakes and it didnt do it this morning on the way to work. I'll see how it goes over next couple of days and get back to you. Cheers for the reply!
May 1, 201214 yr Sounds chain/sprocketish. Check the chain tension as per the owners handbook. Check youve plenty left on the sprocket teeth on both front and rear sprockets. Check that the front sprocket is secure on the shaft, and the rear one on the wheel. Check that the sprockets are in line with each other. Remember to check/adjust the rear brake if you adjust the chain Good luck
May 14, 201214 yr Post Intro in the Intro section. Then check wheel bearings and forks. Then check spokes.
June 29, 201214 yr Author Its stopped now after some tinkering. I want to change the chain anyway as its starting to look tired despite chain lubing it up. What chain do I need. I see 2 different types 428 and 520?
June 29, 201214 yr 428!!!! try ( www.wemoto.com ) it sounds like ur chain is on its way out and they over tightened it making it feel stiff and clunky when slowing down.
July 31, 201213 yr Author Chain and sprockets changed. All good. Still getting a rattle when leaning left over bumps.
July 31, 201213 yr that will be one side of the chain tentioner is slightly tighter than the other or the shocks need adjusting
