April 22, 201214 yr Can anyone tell me what year engine this is by the id numbers on block? The number on block is - J5036E-028527. Thanks, Wendy
April 23, 201214 yr Hi Wendy, Welcome to the YOC, It might be an idea to ask your question in the "WORKSHOP" section of the site as this area is only for intros if you are a new member (which you are) May I also suggest that you do an intro if you would be so kind as most people like to know who they are talking to. Someone will probably be able to help you out with your query if you ask in the right place, good luck in finding out what you want to know.
