Hello its reidybiker here is anyone out there able to tell me please how to turn up two stroke on a dt125Lc mk 3 it dont seem to be smokeing as much as i think it should thanks . Andy reidybiker.
There are 2 adjustments Andy
the first is to align the cable pulley marker and the plunger pin when the throttle is closed, use the cable adjuster for this
then there is the pump stroke checking and adjustment
start the bike idling and watch the front end of the pump, you will see it moving in and out of the pump body, stop the engine when it is out at its fullest extent.
Measure using a feeler gauge the gap between the plate and the raised boss of the pump body, do not force the feeler gauge it should be a light sliding fit, the required spec is 0.2 - 0.25mm. if it's incorrect remove the pulley and you will find shims, add or remove shims to achieve the required measurement...usually this works out as adding shims which increases stroke
