April 22, 201213 yr can anyone tell me what size the front and rear sprockets come has standard on a dtr 125x sm and what sizes i will neeed to change to for top end speed
April 23, 201213 yr Alright mate just checked ebay for you and the standard sprocket sizes are as follows, 16 Tooth front sprocket 57 Tooth rear sprocket if you are after more top end performance the you can either get a smaller rear sprocket or a larger front sprocket, i wouldnt reccomend going to much lower though, maybe just go up a tooth on the front. By doing this you do lose some performance accelerating. In my opinion the bikes are fast enough with the standard sprocket sizes and have great power through out the gears. Let me know how you get on, goodluck! heres a link for the standard chain and sprockets providing your bike is on the title of the listing, http://www.ebay.co.uk/itm/Yamaha-DT125R-DT125X-1989-07-D-I-D-Chain-and-Sprocket-Standard-Kit-/150709232137?pt=UK_Motorcycle_Parts&hash=item2316f86209
April 24, 201213 yr Author Alright mate just checked ebay for you and the standard sprocket sizes are as follows, 16 Tooth front sprocket 57 Tooth rear sprocket if you are after more top end performance the you can either get a smaller rear sprocket or a larger front sprocket, i wouldnt reccomend going to much lower though, maybe just go up a tooth on the front. By doing this you do lose some performance accelerating. In my opinion the bikes are fast enough with the standard sprocket sizes and have great power through out the gears. Let me know how you get on, goodluck! heres a link for the standard chain and sprockets providing your bike is on the title of the listing, http://www.ebay.co.u...=item2316f86209 thanks keiran,with all the mods done to my bike im only getting 65mph from it and wanted to change the sprockets to see if i could get it to do 75mph.would you recommend me only going down one tooth on the back sprocket
